I also ran into this problem. I went to search for the log files and they do not appear in the listed folder. I am not sure why, but I will keep working on it.
@Aliarch I had this same thing happen. It was very strange, but some components appear updated after running the sync while in reality they are not. It happened that about 50% of the BuildingSolid component group needed to be manually replaced, even though they appeared to be the updated version on the GH interface. Very odd. It took me half the day to figure that one out. Try replacing the components for your BREP assemblages (Facade, ratios, programs, buildingsolid) and see if that helps.
I thinks this happen is ran when the Solid workflow is used, inn fact by footprint workflow is not appeared.
finally i could not solve it
I’m using DF 1.8.0 and this error still appears.
