Domestic hot water energy consumption
I know it may be a silly question, but is there any component calculating the energy consumed by domestic hot water usage?
Thank you in advance!
Do you need a component for this, is it not enough to calculate the power to raise the temperature about 50 degrees C and maby some pump energy?
@MaxTillberg
Hi Max,
Thank you for your reply.
For the simplicity of the calculation, the answer is not.
But for curiosity, I tried to find one in HB because as far as I know, the ARCHSIM has this function.
Hi @HAOBOLIU,
Use the “Ladybug_Residential Hot Water” and “Ladybug_Commercial Public Apartment Hot Water” components from Ladybug’s “4 | Renewables” tab. You need the output “heatingLoadPerHour” in kWh.
Modify its inputs to accommodate your building type.
Attached is an example definition.
DHW_consumption.gh (399.0 KB)
Hi @djordje
Thank you very much!
Hi everyone!
I have a question : does Honeybee HVACs and OpenStudio simulation includes service water heating or just building heating?
It might sound like a silly question but there are differences in the US and Polish terminology for some systems.
By service water heating I mean : heating the water for use in sinks, taps, bath and so on…
Thanks for help in advance if anyone find my question here!
Hi @Mike_Rogozinski, did you find an answer?
Legacy Honeybee will never support Service Hot Water but I am planning to add it into the LBT Plugin before the next stable release in another month or so.
Thank you for your tremendous help @chris!
