Energy Shade Benefit Analysis for LBT
Hello everyone,
I attempted to utilize the HB energy shade benefit evaluator in LBT as my Legacy version is no longer functional. @chris, do you have a workaround to adapt your excellent definition to LBT?
I’ve included my Grasshopper script here, and I hope it aids in resolving the issue.
Thank you.
ENERGY SHADE BENEFIT LBT.gh (209.4 KB)
https://hydrashare.github.io/hydra/viewer?owner=chriswmackey&fork=hydra_2&id=Energy_Shade_Benefit&slide=0&scale=1&offset=0,0
Hi @tru ,
The shade benefit workflows were on my agenda for the next release and I have already started work on the thermal comfort shade benefit component, which is the sister component to the one that you are pointing out there.
I have a few planned improvements for the energy shade benefit in particular, which will make it easier to run with large models. For one, I’m planning to write it in a way that evaluates all shades that are assigned to windows, which will make it clear for which window each shade is being evaluated.
I will post back here when it’s available.
Hi @chris,
That’s a fantastic news! I can’t wait to start using the new components.
Will the shading designer and sun shades calculator components be part of the upcoming LBT release as well?
Thanks for sharing this exciting update. I’ll be keeping an eye out for updates.
The sun shades calculator is not part of theLBT. We (@AntonelloDiNunzio and myself) developed it at the time and it was included in the Legacy version.
The good news is that you can still use it since it doesn’t requiere any of the LBT libraries, it works independently. The outputs can be plugged into the shades of the model.
The bad news are that there are some bugs that are still unresolved.
Hi @AbrahamYezioro
Thanks for the clarification. It’s an amazing component, I hope you will be able to solve the bugs at some point.
I’ve observed that it functions well for me as long as I don’t add any context to the input. However, whenever I incorporate any type of context to the input, I encounter the following error messages:
  1. Seems to be that the shading surface doesn’t intersect any sun vector.
    If you are giving a surface for the shadeSurface_ input, be sure that it will affect your window.
  2. No enough intersection points to calculate the shading surface
Are these the bugs you are referring to?
Sun shade calculator.gh (579.2 KB)
FYI, you can see here that I just added the comfort shade benefit component to the LBT development version yesterday:
So you can expect the energy shade benefit capability to be added soon.
I was not planning to bring the Shading Designer component over from Legacy because most of the things that it does are better addressed with other new components. If you are tying to use the Legacy Ladybug Shading Designer to generate louver shades or overhangs, I would recommend the HB Louver Shades component. FYI, this is the component that will be used in the new energy shade benefit workflows that I have in mind.
If you’re trying to use the shading designer for its ability to generate a shade geometry that blocks a set of sun vectors, I just added a more generalized “LB Shade Benefit” component that does an analysis like this except with a more practical result that quantifies which parts of the shade geometry are blocking the most sun vectors. You can use this to perform a wider variety of shade studies like evaluating which parts of a shade might be most useful for blocking direct sun and mitigating glare:
And, instead of having to create a shade that blocks all of the sun vectors (which is often impractically large), you can make an “optimized” one that blocks the most suns within a given area.
Granted, if you give this new component the right set of inputs, you also can do what the legacy shading designer did of making a shade that blocks all suns.
Here is the sample file for that produced the screenshot you see above, though be wary that you will need to run the LB Versioner component in order to be able to run the sample.
Hi @tru ,
No. This is not a bug. In this case seems to be a misunderstanding on the context input. Your context is located at the same location as the shading element is supposed to be calculated (just above the window limits). If you disconnect your geometry you get this:
If you add some “real” context, like surrounding buildings, you can get something like this:
Some of the bugs are related to the option of plotting pergola shadings, which not always work as expected. That seems to be caused by some change on Rhino at some release, and i didn’t succeed in identifying to solve it. There are probably more that i don’t remember now.
Attached your file with the latest version of the component.
Sun shade calculator_AY.gh (588.4 KB)
Hello Chris,
Thank you so much for the incredibly prompt response and the detailed explanation of the workflow. I’m delighted to start using the new components you’ve just developed.
Hi @AbrahamYezioro,
Thank you for the explanation. My intention was to utilize a hypothetical volume of the same building as a context to test the self-shading on the new surface shading. Now I can confirm that it works. I believe in one of my earlier tests, not the one I posted, I might have selected a geometry that is in the same plane as you mentioned.
FYI, @tru ,
The energy shade benefit has officially been added to the latest development version of the LBT plugin:
You can get the new component on your end by running the LB Versioner and here is a sample file demonstrating the new workflow.
The workflow is a lot more streamlined compared to Legacy now that we can assign Shades to Apertures and use that as the means to identify which aperture affects which shade. And it was good to re-evaluate how we were calculating the benefit since I realized that it only took a small tweak to my old code to get the net heating/cooling load savings in kWh by postprocessing the results:
This also marks the point where I can at last I can say that every single energy simulation feature that existed in Legacy is in the LBT plugin. It may have taken 4 years of development to get here but it still feels good to hit the milestone.
Hi @chris
Thank you so much for the update and for putting in a significant effort to consistently update and enhance the tool. I’m delighted to hear that all the energy features are now integrated into LBT.
Chris, just so I understand this correctly, does the red being in negative kWh/m2 indicate the most beneficial location compared to the blue?
No. Red is a bad place for shade where it will increase the space heating load more than it reduces the space cooling load.
Blue is the right place to put shade so that it reduced the cooling load more than the heating load. The darker the blue, the better.
