Error on re-run OSM component: "1. Solution exception:expected Path, got str"
Hi everyone,
I’m having a problem when I plug in a list of OSM file addresses in Honeybee_Re-Run OSM Component.
I’ve tested this on VER 0.0.65(JAN_01_2020) and 0.0.64 (2018-Dec-10) of the component on two different computers and both rhino 5 and 6 and I got the errors every time.
A similar issue has been discussed earlier in here. but as @chris suggested, this one is different from that, so I’m posting it here under a new topic.
Can anyone help me with this issue?
You are using an older version of the component. The fixed version should be dated Dec, 04 2019
@mostapha ,
Thank you for your response,
I tested the latest version of the component ( VER 0.0.65(JAN_01_2020)), but I get errors again:
@Nimafo, thanks. Can you also clarify what version of OpenStudio do you have installed on your machine?
@mostapha,
Sure, It is version 2.9.1.
I changed the version of my Open Studio to 2.5 as it has been suggested here, and now it works fine.
@mostapha thanks for the hint. :slight_smile:
Hi @mostapha , I alse met this error, and after change version from 2.9.1 back to 2.5.0 it is solved. Seems indeed the version is the cause.
