I really think this is something that is best accomplished this using the “LB Create Legend” component. Here’s another discussion for a case where I used it to customize the coloring of face geometry:
The “Create Legend” component is just much more versatile and useful compared to anything that is constrained to only rooms or faces. Sure, it takes some mastery to use but then you learn this one component and then you are set for many use cases instead of just one.
If you really need a dedicated component for coloring rooms, there’s nothing stopping you from writing your own and making your own set of specialized user object using the Ladybug Tools SDK. You can use this class in honeybee and you are 90% of the way there.
