HB+ Custom Radiance Material Modifier Help
I am trying to assign a custom Radiance material to quickly simulate frit with HB+ annual daylight recipe. I’m getting an error when starting the simulation.
What is the easiest way to apply this radiance material? I’ve tried directly as a text panel but it seems to not be supported? I’ve tried applying this modifier to a HB face and HB aperture and get an error either way.
Material definition text:
  void glass glazing_material
  0
  0
  3 0.654047488895 0.654047488895 0.654047488895
  void trans frit_material
  0
  0
  7 0.3 0.3 0.3 0.0 0.0 0.333333333333 0.0
  void mixfunc fritted_glazing
  6 glazing_material frit_material uv_hole perforate.cal -s 0.0762
  0
  1 0.312
Related post: Error when I create a Radiance custom material (HB+)
Thank you!
Hi @rxs5160,
This should still work. You can add glazing_material and frit_material as the dependent modifiers.
Funny enough, that is what I used to create that material! Thanks for the handy python script.
I did check that perforate.cal is located in C:\Radiance\lib
I’m getting this error:
Can you share a sample file with internalized geometry either here or in a private message?
attached is a simplified version with internalized geometry. model is in meters
customfritRAD.gh (124.0 KB)
I should note I am working in Rhino8 but not sure that will make a difference for this issue.
Try to put the cal file in C:\Program Files\ladybug_tools\radiance\lib as well. This should solve it.
That did the trick! thank you
