I’m getting unexpected results for a daylight autonomy simulation and am wondering whether my model has issues or the components might not be working properly. I’m using HB/LB+ …0.04 and Rhino 5.0.
As a test before working on a larger model I created a simple box with a window to the side and a skylight. The first image below shows the simulation using only the side window. The result is a DA of 0.
The second time I included a skylight. The result was a DA higher than 0, but the results appear very random / scattered.
I’ve tried updating components to v05 but I got the same issue as Jan here:
Using only HB legacy components, the simulation did work (see last image).
For both cases I also ran an illuminance simulation with HB+ components for which the results do make sense.
result with side window only:
result with skylight:
lux simulation results:
Result of the simulation using HB legacy components (expected results):
Grasshopper file:
Annual Daylight Simulation Test R1 [HB PLUS] v2.gh (526.4 KB)
