Dear community,
After many years of working with the great LB HB legacy, I am testing the 1.3.0 release.
I made a simple shoebox model for energy analysis and given a set of shades through the HB shade 1.3.0 component, I notice that these will not affect results on HB Peak Loads and HB Annual Loads, while HB Model to OSM takes them into account
I tried many code configurations and geometry types (input from Rhino or generated with GH), but unfortunately results are not changing.
I have attached the model.
@chris or @mostapha any hints?
Your help and suggestions will be very appreciated!
Many thanks in advance
Alberto
XXXX_shoebox_AB_210917 for forum.gh (190.0 KB)
xxxx_shoebox_210918_AB for forum.3dm (82.3 KB)
Hi @alberto.bruno , I checked your .gh definition. Although I am not able to notice same results for with and without shades for peak loads and Annual loads calculation. The results do vary in the expected manner.
With Shades
without shades
Dear @maheshjayayachander many thanks for the prompt feedback.
I re run the code on two different laptops (one with Rhino 7, the other with Rhino 6).
I have also updated the components with LB Versioner (in case it helps…) and checked the plugins on both:
I wasn’t lucky: the results are not changing again.
Thank you again,
Alberto
Hi @alberto.bruno
I seem to face the same issue where the results do not change with or without HB shades. Did you find a resolution to this?
