I am trying to remove IronBug (and HB/LBT) from my system so I can do a fresh reinstall (having lots of version issues at the moment, trying to fix…)
So far I have:
- Removed C:\Ironbug\…
- Removed ‘Ironbug.ghlink’ from …\Grasshopper\Libraries\…
- Removed Ironbug.LBHB_Legacy.gha from …\Grasshopper\Libraries\…
- Did a full search for any other files with ‘IronBug’ in the name
However, I still get this error whenever I try and start Grasshopper:
The error reads:
Priority: GhpyLoader
The Rhino IronPython plug-in could not be loaded. It was either disabled, or it cannot load on your system.
ApplicationException
Error export files is attached here as well.
I wonder, can someone let me know where else I should clean out or remove to resolve this error? I’m just trying to clean everything away / get back to zero at the moment. Any advice is much appreciated!
best,
@edpmay
GH_Load_Ex.txt (165 Bytes)
