Help with Vector Output in Solar Analysis using Grasshopper
Hi everyone,
I’m currently working on a solar analysis project in Grasshopper. While setting up the workflow, I encountered an issue with generating the vector output correctly. Despite following typical steps for solar vector calculations (using components like Sunpath, Vector XYZ, or others), the output seems either incorrect or non-functional.
