I want help with Ladybug's solar radiation analysis and EPW file problems for Grasshopper
Hi everyone,
I am new to using Ladybug for Grasshopper and could use some guidance. I am trying to analyze the solar radiation on a building façade but I am not sure how to efficiently set up the geometry and simulation parameters. Are there best practices for optimizing the analysis when working with complex shapes or irregular surfaces?
Also, I have been facing issues with importing weather files sometimes the EPW file is not recognized properly. Is this a common problem & are there any troubleshooting steps I should know about ?
I would appreciate any guidance on integrating workflows with tools like EnergyPlus for more in depth analysis, as I am a cloud engineer by profession and hope to expand my skill set.
Also i have check this Help with Vector Output in Solar Analysis using Grasshopper If you have tutorials, tips or example files please share with me.
Thank you:)
Hi @jarethdf, there is an example file for radiation study it can be downloaded here
