I am using honeybee green roof model and trying to use all the inputs of EnergyPlus Material: Roof Vegetation.
I am using the latest version of Honeybee and HB Vegetation Material. But sadly there ist some important data missing, that I cannot specify in the Material, e.g. Moisture Diffusion Calculation Method.
There are very useful tips using this in Honeybee Legacy, just plugging the Data from the Material: Roof Vergetation into EP Construction and off we go.
So I simply used the old Honeybee Legacy EPConstruction and plugged it into the ne Honeybee HB Exterior Construction. No errors, just a slightly higher EUI - probably resulting from the different parameters.
Am I missing something? Is it feasible to use HB Legacy and the latest Honeybee in one simulation?
Thanks in advance!
