hi,
I am try to run annual daylight analysis but keep showing error. @chris would you please help me?
thanks
This is likely the same issue that people experienced in the last release when they used non-standard types of Weas. Try running the LB Versioner and restarting Rhino. That will likely fix the issue.
If the issue persists, please upload a sample file to recreate the issue.
