as per title, very simple question:
How can one merge multiple .ill files created when running radiance analysis with multiple CPU in honeybee?
thanks
thanks
They are just csv files with no header. If you use readAnnualResults I component it automatically does it for you. Are you looking to a command/script to do that?
I would like to export have in one file, with the same structure of the ill files, so that I can do some further post-processing outside grasshopper.
any way I can do that?
thanks!
For that case you can run this command inside the folder to create a merged.ill file from all the files that ends with ill in that folder.
copy /b *.ill merged.ill
my ill results file are like:
hour_1, value_point1, value_point2, ā¦, value_pointN/number_CPU_used
hour_2 value_point1, value_point2, ā¦, value_pointN/number_CPU_used
ā¦
hour_8760, value_point1, value_point2, ā¦, value_pointN/number_CPU_used
The command you suggest merge them staking them on top of each other.
but I would rather have something that stack on the side (without the time), i.e. a ill file with the value for all the points.
I guess I can do with some small scrips, but I was wandering if I can do this automatically in grasshopper/honelybee
thanks!
