Hi, I am trying to run an radiance energy simulation but I am having an issue with the runenergysimulation. Attached below shows the error " 1. Solution exception:HBHivegeneration " when i turn on the boolean toggle at _writeIdf .
You connected the simulation outputs to HBGenerators_ instead of simulationOutputs_. Try fixing that first then check if you have issues with your OpenStudio/EnergyPlus version.
The legacy version of honeybee is compatible with OpenStudio 2.9.1/EnergyPlus 9.2.0 which can be installed here:
Hi Ken, noted I have connected to simulationOutputs_ and now I do not have an issue with writeIdf when I Switch On the boolean toggle. However, when I Switch On the runEnergyPlus , I am getting an error shown in the image below:
I didn’t have that error when running the model on my end.
This error happens sometimes when you have the wrong version of EnergyPlus installed. From the error log, it seems like you also have EnergyPlus 22.1 installed. Do you possibly have the latest version of OpenStudio installed on your computer?
I would recommend you only have OpenStudio 2.9.1 on your C:\ drive so honeybee can recognize the compatible version of Energyplus. Otherwise, updating to the latest version of Ladybug tools allows you to use the latest version of OpenStudio and have better version control in general.
Thanks for your reply and I tried installing Open Studio 2.9.1 and uninstalling Open Studio 3.4.0 but I am having the issue “1. you need to let both Ladybug and Honeybee fly first!” which appears at the 1st and 2nd image.
When I tried to update ladybug and honeybee, It shows the same error “1. you need to let both Ladybug and Honeybee fly first!” shown in the 3rd image.
You need to insert the Ladybug_Ladybug (and probably the Honeybee_Honeybee too) component on the canvas.
… BUT … why are you using the Legacy instead of the new (and better) LBT?
