Good Morning @mikkel , I tried to create the blinds as simple surfaces (only one flat blind surface per window) to simplify the geometry, maybe that could be the problem, but it brings me the same error [fatal - unexpected EOF in header].
I now read your response to this post: Error when I create a Radiance custom material (HB+) - #2 by mikkel, couldn’t I use this type of script to give out the mixfunc perforated material and bypass the RadScene?
Thanks for @mikkel ! This method to construct the perforated is interesting! It can be seen that the component is working. But I have some confusion in control the number of perforation because of the parameter in the component. I can undestand the size is to control the the number of perforation of column and row, but it is may be lost my control. I want to control the number of perforation by two parameters including the number of column and the number of row. Such as these potho displaying,
column 20, row 1 radius 0.94
I try to modify the “perforate.cal” to achieve the requires. But it’s diffucult for me to read the code. So, I wish you can give me some advice to me in modifing the code.
Best grateful for you!
P.S.: without the perforated material the simulation succeded. I have also specified the full path to perforate.cal as C:\Radiance\lib\perforate.cal even if the perforate.cal file was in the LBT folder (C:\Users\luciano\ladybug_tools\Radiance\lib).
I’m trying to model a perforated mesh, something I’ve successfully done before using the legacy version of LBT without any issues. However, with the newer versions of LBT, the PIT component consistently fails and throws an error. I even tested it using the same file from HydraShare, it works perfectly with the legacy version, but not with the newer LBT versions (1.6 and 1.8), which is quite puzzling. The geometry and settings are identical, yet the newer versions break when the perforated mesh material is included. If I remove that material, everything runs smoothly, so it seems the problem is related to how the latest LBT versions handle perforate.cal. Do you have any idea what might be going wrong or how I can fix this?
Hi @mikkel, sorry to bother you with this. Do you have any idea what could be happening? i tried in other computers (not mine) and the issue dissapear, i have already try to uninstall and reinstall Rhino and LBT or even update it to the newer version, but still the same error appear, it is quite frustrating. And it is not just with the PIT component is happening with all the Radiance simulations when i try to include a perforate.cal Radiance function.
