I am trying to determine the airflow rate of an IdealAirLoads system. Looking at the RDD file, I found three outputs that might be helpful:
Zone Ideal Loads Outdoor Air Standard Density Volume Flow Rate
Zone Ideal Loads Supply Air Standard Density Volume Flow Rate
Zone Mechanical Ventilation Standard Density Volume Flow Rate
The first and third have the same constant value, while the second appears to go above this value during times when the system is cooling:
Can someone please explain what these outputs mean and why they are not all the same?
IdealAirLoads Flow Rate.gh (547.0 KB)
