Hi Chris and ladybug team, I installed the latest version of ladybug and honeybee, and I still getting this error: 1. The simulation has not run correctly because of this severe error:
2.* Severe ** [ShadowCalculation][ShadowCalculation 1][shading_calculation_method] - “AverageOverDaysInFrequency” - Failed to match against any enum values.
3. The simulation has not run correctly because of this severe error:
4.* Severe ** [ShadowCalculation][ShadowCalculation 1][shading_calculation_update_frequency_method] - “30” - Failed to match against any enum values.
5. The simulation has failed because of this fatal error:
6.* Fatal ** Errors occurred on processing input file. Preceding condition(s) cause termination.
Someone told me this was due to and overhaul caused by the Energyplus version, is there anyway to fix it?
