Glad it does!
Ok, now there is another issue:
I have used the 02_0_indoor_airflow.gh example file taken from the …butterfly-plus-master\plugin\grasshopper\examplefiles folder.
The caseFromGeos component creates the case:
The components blockmesh and snappyHexMesh seem to work properly:
But the Butterfly solution component reports a Foam fatal error:
Cannot find file “points” in directory “polyMesh” in times 0 down to constant
Solved, simply by adding the boolean button setted to “true” to the “run” input of blockmesh and snappyHexMesh components:
