I have encountered a very curious feature with installation of Mac versions of LBT.
I have a class of 330+ first year students due to front up to a tutorial in two batches of 160+ on Monday at 8:30am, and I have encountered a weird issue with the check versions component. (it is Friday evening now)
I have asked them to install the software (which should have been done in a course in the first trimester, but not all students followed those instructions. They are then to run this attached “check versions” script.
Oddly, I encountered the component error but for a very weird reason:
As can be seen, the check versions component reports it is from an old version of python but notes the error is because the open studio application has not been installed properly.
At first I thought this was a problem that students had been installing the INTEL Open Studio instead of the ARM version. But, apparently not.
What has solved the issue on a colleague’s and on a student’s Mac is to install the OpenStudio program, instead of the Open Studio App.
Just installing Open Studio 3.7 and restarting Rhino produced the following output from the Check Versions .gh file I had distributed.
This error message on a student’s “brand new” Apple computer, seems to indicate an error with the grasshopper installer from Food4Rhino and the CPU. Odd?
There seems to be a link to this entry Mac Installation but I cannot think of why there should be an “executable error” with the grasshopper files?.
The computer uses the new M3 chip. “Bad CPU type in Executable” when the executable is the Python script interpreter is an issue I am struggling to figure out.
I don’t really know what is happening either to cause the “Bad CPU” error. This is the type of thing where Google is going to be more helpful than anything I can say. It looks like this person solved it for themselves here:
And, yea, Ladybug Tools uses OpenStudio SDK not the OpenStudio Application. The two are different installers that install different pieces of software so it’s not going to work if you install the OpenStudio Application in the ladybug_tools folder.
The student and a colleague report that the solution that worked for them to the M3 execution error was the following:
Hi Michael,
Yes! I found the Rhino file and successfully ran the daylight/shoe box file.
Yiwen and I found that on the new MacBook laptops, we had to first install Radiance and OpenStudio BEFORE installing Ladybug [this is different to the installing video which installs Ladybug first]. After installing these two applications, force quite Rhino and install Ladybug tools [if LadyBug is already installed like mine was, we just needed to delete the Python folder and Python zip file and then click the 2nd toggle to true]. This should then successfully install the Ladybug tools after force quitting and reopening Rhino.
Hopefully this has made sense!
H…
This solution makes no sense to me - especially deleting the Python file.
It’s weird, @MichaelDonn , but I could see that maybe the Radiance or OpenStudio installers changed something about how the Mac runs Python. I know Mac has always had a weird relationship with other Python installations on the machine (like what Ladybug Tools uses) because Mac OS ships with a version of python that gets used internally. And I also know that OpenStudio, in particular, has been adding a lot of new capabilities to run Python measures that might change some of the default Mac settings.
In any event, I would guess from the description above that there’s no need to do any deletion. Just Install OpenStudio and Radiance before Ladybug Tools if you want to have it work out of the box.
Although I am joining the discussion late, I believe the root cause of the issue is the current installer downloading an Intel-based Python executable that necessitates the installation of Rosetta2. When installing OpenStudio and Radiance, the system prompts users to install Rosetta2, which subsequently enables Ladybug to function. In contrast, the installer for Grasshopper does not trigger this prompt, causing confusion among users.
If you already have some Intel-based software running, you could potentially install Ladybug before Radiance or OpenStudio without encountering any difficulties.
That sounds like a good explanation @ccyen so I’m marking it as the solution. Before I release the next installer on Food4Rhino, I’ll try to see if I can sense the CPU used and try to give a warning if it’s not Intel.
Given that the only Mac I have access to use intel based CPUs, I might need someone else to test but I sense that we should be able to give a warning about the need to install Rosetta2 in the installation process.
FYI , @ccyen . The installer.gh file for the LBT 1.9 release that I just made will give a warning to install Rosetta2 if the CPU type is sensed to be ARM64.
Hopefully, this helps avoid confusion for the Mac users who install Ladybug Tools but do not install any of the engines (maybe because they only plan to use it for climate graphics).
If you test the LBT 1.9 installer and let me know whether the message the installer component gives is clear, I would appreciate it. I don’t have an ARM Mac to test all of this myself.
@Nicholaskerr would you be able to test this on your Mac?
Also, when you do, could you inform Stewart Milne in the tech office what version of IronBug is installed - I am guessing to do what you did, and continue into the second half year your Open Studio App will need to be upgraded to 3.9 (to edit the Ironbug and graphically represent the HVAC plant) ?
