Integrated parametric design of adaptive facades for user's visual comfort
Dear All,
I have recently published a peer-reviewed paper in Automation in Construction journal. This paper aims at designing an adaptive facade that can be controlled within a ‘Timing Pattern’ by user for each hour to control visual comfort (especially glare and illuminance)… The workflow is done by Ladybug-tools and the prototype itself has been published in USPTO in 2018.
Thanks for your sharing and interest in advance.
@AMIRTABADKANI Well done! Thanks for your nice workflow.
Hi @AMIRTABADKANI , congratulations on the patent! If your article is not under the publisher’s embargo, can you share a pdf of your journal article?
Thank you @sarith for your interest… you can have access to pdf through this temporary link …
https://authors.elsevier.com/a/1ZD8K3IhXMfacG
Thank you so much @AMIRTABADKANI. I am considering starting my PhD soon and I am inspired! Lovely work indeed with your team.
Thank you for sharing @AMIRTABADKANI.
