Hi
I’m trying to run an energy simulation using ironbug detailed hvac system.
to define a dual setpoint (one for heating and one for cooling), I used the workflow below:
(everything is the default fancoil+doas system except for the setpoint)
and got this error:
- ** Severe ** [Schedule:File][cooling_setpoint] - Missing required property ‘file_name’.
how can i solve it?
Also is this the right approach or should I use the “IB_SetpointManagerColdest” and “IB_SetpointManagerWarmest” components?
[OpenStudio 3.4.0 / installed ironbug using pollination, which updated the LBT to 1.5]
Thank you so much in advance
