Issue Running Single-Hour Glare Analysis in Honeybee
I am currently working on glare analysis using Honeybee, and I am facing difficulties when trying to run a single-hour glare simulation.
  • My goal is to obtain Daylight Glare Probability (DGP) values for one specific hour in the year.
  • I tested both the HB Annual Glare (imageless glare analysis) and HB Glare from HDR workflows. In both cases, the results are either zero or unrealistic.
  • To control the period, I used the Analysis Period component for one hour. I also tested with a Clear Sky component to define specific day/hour conditions. However, the outputs remain strange (either 0 or not matching expectations).
  • I also tried multiple weather files (Charlottesville airport, Richmond, Los Angeles, DC), but the issue persisted.
I have attached my Grasshopper file and screenshots showing the setup (annual glare, analysis period, and sky components connected).
Could anyone advise on:
  1. The correct way to extract DGP for a single hour in Honeybee?
  2. Whether this workflow requires a different approach (e.g., point-in-time glare analysis instead of annual glare)?
Thank you in advance for your guidance!
somaya’s office.gh (449.1 KB)
Hi @Rahaf03, I could be wrong but if I am not mistaken, the start and end hours in the analysis in your case should look something like:
  • start_hour: 16
  • end_hour: 17
    that way the analasys period spans an hour.
    I wasn’t able to test it as your uploaded file doesn’t have a model in it.
Hi @Rahaf03,
If you are only looking at a single hour, then I would not use the imageless glare analysis. In any case you should be aware of the limitations of the imageless method; you can read more about this under Recommendations (page 7 of 8) in Nathaniel’s paper.
For the HDR method you should use Point-in-Time View-Based to generate the HDR image.
Thank you both
can I use the HDR-I result from HB analysis in evalglare ? because when i try to check the HDR-I in its location it’s always just a white image with nothing but white color.
Also, I always have the same results for DGP even when I change the day or sky type.
friendly reminder
Friendly reminder
Hi @Rahaf03,
Please share your file with internalised geometry either here or in a private message.
thank you
Hi @Rahaf03,
Here are some things you can do improve the setup. I added the changes to the attached file.
You do not need the modifier subset. Instead you can add the modifier directly to the shade objects.
For the tree geometry I suggest that you convert it to a mesh. This will significantly reduce the number of polygons in your case. You can read more about the ShadeMesh object here.
The first two are mainly optimizations. The next one is required.
The aperture was added to the model several times. Below is the correct way to add the aperture as a subface. Basically, because the aperture is added to the room, you do not need to add it to the HB Model component as well.
Thanks a lot, can I ask about the artifical lighting modeling.
in the HDR-I they didn’t appear
