Hi!
I have installed Ladybug+ and I´m a bit confused to why most of the tools from the legacy Ladybug is missing? Is it ment to be used in conjunction with the legacy tools or did something go wrong with the installation?
Refer to image for Ladybug+ tools.
Hi Andreas, LB+ and LB legacy are 2 different things. If you need components (and workflow) from the legacy version, you will have to install that separately.
