I am currently running a simple radiation analysis in one window. I wonder why there is such a big difference between the two of them, they both have the exact same inputs but the results are quite different. Which of them is the right one? Where is my mistake?
Julio
The LBT one is more accurate and it’s primarily because it includes the contribution of ground-reflected radiation using an emissive “ground hemisphere”. See here for a longer explanation:
Hi, I think the LBT (1.4.0) “LB Incident Radiation” takes into account the bottom face of a brep/mesh, which overestimates the total radiation from my test. The older one “Ladybug Solar Radiation” works fine, which always assigns 0 value to the bottom face. Maybe this is one of the reasons resulting in the huge difference. And I think there is one more issue regarding the “context” in “LB Incident Radiation” but I am not sure. Looks like the simulation result would not change with the “context” when I tried to simulate the radiation on the bottom face.
