I keep having this error even after uninstalling/re-installing LBT 1.4 several times, synchronizing gh file etc.
I also have an error with the “LB sky dome component” => max () arg is an empty sequence.
Note I always work with model units “meters” and that all the other components for LB, HB and HB- radiance and HB- energy are working well.
Has anyone had this issue before? How can I fix this?
Thanks for the prompt respond. I am using windows OS but I had the Radiance version 5.0.a.12 installed (default version that comes with Openstudio 3.3.0) instead of the 5.4a version.
Thank you very much for confirming this, @ffotsing . I didn’t realize that some of the very old versions of Radiance released by NREL do not have certain functions that we’ve been using to check the version. I just pushed an update to the development version of the plugin that will work around this case:
Now, in the soon-to-be-released LBT 1.5, people should get a clear message telling them that their version of Radiance is too old to be used with Ladybug Tools:
