Hey @AbrahamYezioro ,
A gew of things:
- There is 100% support for all Legacy shading control features via the
WindowConstructionShadecomponent in LBT. The only thing that is arguably missing is the dynamic behavior of the windows in the comfort maps. Is this what you are in need of? If not, then you should really use the LBT plugin. - The Legacy has absolutely no knowledge of the folder at
C:\Users\[USERNAME]\ladybug_toolsso it is impossible for it to find an OpenStudio installation there. So just install OpenStudio there any everything will be fine. - The LBT plugin is not currently compatible with OpenStudio 3.0.1 (not the last stable release nor the development version). If you’re using the development version of LBT, then you should just install OpenStudio 3.2 in the
ladybug_toolsfolder. - Just making sure that we’ve checked all the boxes but did you set up OpenStudio 3.0.1 for compatibility with legacy as noted here (How to get Honeybee Legacy working with OpenStudio 3.0)?
