I am also having trouble with this, how do you work out what version you need from the matrix? thanks
First, don’t use a plugin from 6 years ago. There have been several new releases on Food4Rhino.
Second, install Radiance in C:\Radiance instead of C:\Program Files\Radiance.
Thanks for the reply, however, I am not able to get Ladybug to work. When I open the install .gh file the second toggle “collects no data”
What am I doing wrong to get Ladybug plugin working? Thanks
Maybe your internet connection was dropped while trying to run the component. Try running the second component again and give it a few minutes to be sure that it ran to completion.
