I am running an outdoor study and observe that the Butterfly_Load Probe Values component outputs velocity values for different number of points. This number changes with iterations. It does not output values for all the points I supplied as probes. Is this normal?
I would like to report that this is not normal at all. I advise to stop the solution immediately. Like most issues in running CFD, the source of this issue lies in insufficient meshing.
hi @OlivierDambron,
Can you kindly download the file from this thread. This thread is about the same case.
I also did some search and found that there’s component for skipped probes?
Looks like @mostapha and @TheodorosGalanos envisaged this.
