Loading user therm material library into honeybee therm
Hi everyone.
I have simple question about loading THERM material of my computer.
My goal:
As I have few material added in personal therm material library, I want to load them into honeybee and use it while assigning material.
The problem:
However, every time I execute honeybee_honeybee I think it downloads a new thermMaterial.csv file.
Here’s the difference between thermMaterial file of mine and that honeybee loads.
What I’ve tried:
I exported my therm material library as .csv format and put it in the honeybee default working directory(c:ladybug). However, results are always same. It downloads new thermMaterial file from (https://raw.githubusercontent.com/mostaphaRoudsari/Honeybee/master/resources/thermMaterial.csv) and load newly produced file.
Is there any method to bring my own therm material library?
Thanks for your help.
@Keani ,
Did you completely overwrite the thermMaterial.csv or did you just paste your custom CSV in the ladybug folder? You’ll need to completely overwrite the thermMaterial.csv to prevent it from re-downloading and re-loading it each time.
Hi Chris. Thanks for your reply.
How can I completely overwrite csv file by the way? I think I just copied and pasted it.
Hi, @Keani or @chris
I have the same issue and didn’t quite understand how to overwrite the file.
do I need to change something in the directory of the gh script?
Thanks for any assistance
