Modelling Water with Radiance
Hello there,
I am doing some Glare analysis for which it would be fundamental to model water properly.
I am having difficulties to input the materials definitions I have found in this Link in the honeybee library, I think I am formatting the string not properly,
Any suggestion?
Thanks!
Hi Amedeo,
You can do it as simple as adding the materials to the library and apply them to surfaces. Just make sure to create the wave.cal file and copy it inside c:\radiance\lib. Here is the results:
Check this Hydra for one of the approaches mentioned in the link: (http://hydrashare.github.io/hydra/viewer?owner=mostaphaRoudsari&amp…;)
Thanks A lot Mostapha!
Hi Mostapha,
Thank you for this post, We all proud of you.
For one educational project, I am trying to evaluate the effect of thick water wall on daylight distribution inside a room. (as you know it is not possible with glass material)
this water wall is oriented to the south with thickness about 25 cm.
I have defined a dielectric material in radiance for Water as this:
void dielectric Water
0
0
5 0.8695 0.8695 0.8695 1.33 0
#red_transmissivity green_transmissivity blue_transmissivity index_of_refraction 0
Therefore, I defined 2 surfaces for front and back and since there is just one layer of dielectric, I don’t need using any interface material. But the direction of these surface is very tricky. both directions have to be toward outside (?)
should I rotate them inside in reverse ray tracing??? The resultant values are significantly different.
any comments would be really helpful for me.
thanks in advance.
Hi Mostapha,
I am trying to make some illuminance analyses, my building is very near to river, so i think that it would be good to consider reflectance of water. I have found this example but,I could not find the `‘wave.cal’ file to copy it to rad. library.
The link that you gave in 2015 is not available.
I found sth like this (https://www.radiance-online.org:447/pipermail/radiance-general/2005-April/002584.html) but also I dont know how to create a .cal file.
Paste the below formatted text into Notepad (or any other text editor) and save it as wave.cal in the lib folder of your Radiance installation (Most likely C:\Radiance\lib if you are on Windows). lib folder is the one that RAYPATH variable points to in your Windows environment.
	Ripples for water, whatever
	04Mar90
	A1 = degreee of waviness
wave_x = wave_mag * noise3a(Px, Py, Pz);
wave_y = wave_mag * noise3b(Px, Py, Pz);
wave_z = wave_mag * noise3c(Px, Py, Pz);
wave_mag = min(A1, .5*Rdot);
Regarding this…
I am not sure if using wave.cal specifically would be useful. As you from the definition for wave.cal, it is generated with a noise function and thereby has an element of randomness to it. That randomness looks realistic in rendered images but might create issues with illuminance-based calculations as the wave pattern might create random distortions in your results. It is also likely to be impossible to keep your results repeatable as the wave patterns are likely to change every time you run a new simulation, even for the same model.
Reviving this topic, @mostapha, @chris, @mikkel and team, please would you be able to give an overview of how to do this in the current version of LBT?
I’ve looked at this:
And tried to understand what the code behind the old LBT screenshot above is doing on the back end, but sadly failing to understand what to do.
As an attempt, so far I’ve tried adding “wave.cal” here
C:\Program Files\ladybug_tools\radiance\lib
And have created “water.mat” and “wavey.mat” here (although this was largely hoping and not knowing what I’m doing!):
C:\Users\cbrooker\AppData\Roaming\ladybug_tools\standards\modifiers
water.mat
wavy glass water
0
0
3 0.51 0.62 0.72
wavey.mat
void texfunc wavy
6 wave_x wave_y wave_z wave.cal -s .05
0
1 .25
However getting this error in GH
Thanks in advance,
Charlie
Hey @charlie.brooker ,
Here is the best practice for how to do it with LBT:
water_cube_example.gh (16.8 KB)
Note that you still have to copy the wave.cal to:
… in order to get it all to work.
I’ll also admit that you can put the water material into your custom library of modifiers but the order matters since honeybee needs to find the textfunc before it finds the glass modifier. I feel like the best practice is just to keep it all in the .gh document but, if you want to get water in your library, I suggest putting it all together into one .mat file like this:
water.mat (109 Bytes)
Thanks Chris - appreciate it!
Hi @chris and @charlie.brooker
To import this material, I have placed the file in the rad format in both folders and it is sorted in my modifier list. But the error still exists.
Is the rad extension wrong? And should I use cal?
thanks in advance
You should copy wave.cal file to C:\Program Files\ladybug_tools\radiance\lib.
wave.zip (288 Bytes)
thanks @minggangyin
but i mean the perforated material not water.
as you can see on the white panel i have a script about perforated wall
have you meant i should save this script in .cal format?
Yeah.Radiance has the perforate.cal in lib folder.
here is the full code, save it as perforate.cal.
	perforate.cal
    Perforation function for approximately horizontal surfaces,
	for use in a mixfunc. Foreground is solid, background the holes.
	Set background to empty for a true perforation, or to a different
	material for polka dots.
	Relative hole size is determined by A1.
    Size of single circle is 1 - scale as required (eg. 0.05m).
	x_hole cuts holes in x-direction (through the y-z plane)
	y_hole cuts holes in y-direction (through the x-z plane)
	z_hole cuts holes in z-direction (through the x-y plane)
    Georg Mischler 30. 04. 1993
`xn = mod(Px, 1) - 0.5;
`yn = mod(Py, 1) - 0.5;
`zn = mod(Pz, 1) - 0.5;
{uv coordinate mapping}
`un = mod(U, 1) - 0.5;
`vn = mod(V, 1) - 0.5;
{uv mesh coordinate mapping}
`lun = mod(Lu,1) - 0.5;
`lvn = mod(Lv,1) - 0.5;
`outofcirc(x, y, r) = if(sqrt(x*x + y*y) - r, 1, 0);
z_hole = `outofcirc(`xn, `yn, A1);
x_hole = `outofcirc(`yn, `zn, A1);
y_hole = `outofcirc(`zn, `xn, A1);
uv_hole = `outofcirc(`un, `vn, A1);
luv_hole = `outofcirc(`lun, `lvn, A1);
{ end of perforate.cal }
thanks @minggangyin
I want to see if I understand it correctly in general.
For example, for every material mixfunc I want to use, I first need to create or download the script for use in Ladybug Tools environment (fig below) and then create or download the .cal file for it and put it in the Radiance library?
And if so, is there a database where I can download both of them at once?
Capture
