I’m trying to get unique names for different grids created with the GenPts
component, like so:
I’m following this and this discussions, but the instead of getting the names I set I’m getting None as the name for all grids.
Checking the code of the HB_SetIdentifier
component i see that the last line is:
hb_obj.display_name = None
If i comment this line i get the grids’ assigned names. I wonder if this code line is affecting whether I can identify each grid by name in post-processing analysis (grid filter). Also, it is OK to comment that line?
Attached the file where I’m trying to understand this issue.
NameGenPtsGrids.gh (63.5 KB)
