OpenFOAM installation
Hello, Viola and Devang. I have successfully installed the open foam version 1612+ as described by devang.
1st i installed docker toolbox separately and than ran the open foam setup file. This solved my issue. While installing open foam i unchecked docker installation. I updated butterfly and it is good to go now.
Thanks for the valuable input.
