I have been applying the TM59 script you had previously posted. (CIBSE TM59 - Grasshopper Workflow - #2 by mostapha - Grasshopper Plugin - Pollination Discourse)
Its really helpful (thanks!) and works well with single zone models but recently I noticed some things when working with more zones:
Using your TM59 script for multi zone models causes the results to double up and also the first zone always has a results that is “fractional”. This does not happen when I input just one zone from the exact same model. I noticed the data only doubles after the “LB apply conditional statement”, so possible its the true/false results and I need to remove the falses?
Whenever I test multiple zones using the TM59 script, the flip component gets an error saying “1. All paths in the input tree must have the same length” but no error when testing one zone.
GH.zip (239.0 KB)
