i’m trying to check the behaviour of pcm inside an external wall construction.
I had problems on additional strings linked text, probably the error is on how i wrote it.
Pictures of the error are linked below
Thank you all!
I suspect this is an error coming out of the weather file. Can you try Boston weather file and report if the error persists?
I am not sure which post you’re referring to
this one
Hi @Andrea_Tale, i am trying to add a PCM material to my wall structure, but i cannot find that “EPMaterialWithPCM” module like you do. So, what should I do to add that module in my honeybee? Is there any additional module that I have to download?
