I have a problem with running blueCFD-Core 2017-2.
I’m following the instructions on Github and using the recommended installer (blueCFD-Core-2017-2-win64-setup.exe).’
I can complete the installation, but when I run the blueCFD-Core terminal
I don’t get “Environment is ready”. Instead I get the below.
Accordingly, the meshing in Butterfly doesn’t work as well.
Thanks!
Thomas
The solution was to not (!) follow these steps of the installation instructions on GitHub.
- Right-click on the
shortcut and select “Run as administrator.” A terminal will pop up and a series of commands will run.
- Once the the command reads “Environment is ready”, it is safe to close out of the terminal and you have now successfully in stalled blueCFD-Core!
Instead, I reinstalled blueCFD and didn’t touch it at all but immediately ran the Outdoor example file for Butterfly. Now everything seems to work
nach
3
Interesting, I’ve tried doing the same and it keeps showing the same error on the block mesh component as per this post. Block Mesh not running .
I’m a bit stucked and don’t know how to solve it at the moment.
I belive that that’s a different error, for which I have posted a solution here.
