Problems with HoneybeePlus component
Hello
I am experiencing problems when i am trying to run a script that is built on honeybee plus components.
This is the error message i receive on several of the components:
  1. Solution exception:
    Failed to import honeybee:
    No module named honeybee.hbsurface
  2. Solution exception:
    No module named honeybee.radiance.analysisgrid
  3. Solution exception:
    No module named honeybee.radiance.sky.skymatrix
(Same message, different components)
I have the newest version of HB, LB, HB+ and LB+ installed.
What am i missing here?
Hope someone can help me out.
/Nicolaj
Hi everyone,
Having similar issues here. Did fresh install of all latest components including ‘pip installs’ for both honeybee and ladybug modules but getting following errors:
no module named honeybee.hbsurface (or honeybee.XXXXX)
Same thing happens for ladybug modules.
Lorenzo
@nicolajlangkjaer this solved the issue for me:
I realized I was missing all these folders and rhinoscript files in the Rhinoceros/6.0/scripts directory (prob due to some issues I’ve had with admin privileges during installation). I just pasted these folders from someone who had them installed and everything works.
This is a long shot, but I’m having the same problem as you were (back in July). Any chance you could post a zip of these files or something? I can’t tell which files I’m missing! Thanks!
hi,@870374 Please update your profile. Here is scripts for HoneybeePlus.
scripts.zip (647.9 KB)
Thanks.
I have loaded most of them. That did not solve the first problem
It was mostly about updating the locations of the libraries via the improved Honeybeeplus updates.
I will check out these later this evening.
M
Minggangyin
I already have all these scripts loaded into the right location in Rhino support files. Downloaded from github
Thanks anyway
M
Hello
Dear friend, where should we put this file in Windows? I will put it in the C drive, but the problem will not be solved !!!
Can you give me those files too? Thankful
