Processing HDR images / falsecolor2 palettes & the new image viewer
Hi guys,
First I’d like to thank Mostapha, Chris, Mingbo and everyone who made LB+HB in general, and the last release in particular, available to us all.
I have a specific question related to HDR images, output from Radiance (or not necessarily in my case, but processed using Radiance/pcomb).
Has anyone tried to apply bespoke or unusual gradient palettes to their false-colour images ?
It would be so great to be able to process images like grids, using a preset library much like this:
https://github.com/mostaphaRoudsari/ladybug/blob/master/resources/g…
I used to use the 5 available palettes described in A. Jacob’s Radiance Cookbook (+ bespoke ones) on the command line with the old falsecolor.pl , but I don’t think these are available now with falsecolor2.exe… am I right?
I am aware of the alternative old palette -spec but in the current HB false-colour component, but is that it ?
Another question for Mingbo - I get the following error message when trying to open the attached HDR file with your amazing new viewer: 1. Solution exception:Parameter is not valid.
Am I doing anything wrong ? I can see many useful applications to your pixel-value reader, especially if externally rendered HDR images can be loaded (which is the case here). Do they need a specific header to be “valid” ?
Many thanks in advance for your help.
Jocelyn
test.hdr (429 KB)
Hi Jocelyn,
I can only answer your HDR error question:
I just tested your hdr file, it works fine on my side. I am not sure what caused that error.
I will test this file on my another computer tomorrow, and will let you know if I find the same error.
-Mingbo
Hi Mingbo,
Thanks for your reply.
That’s odd, I have tested on another computer too and get the same error.
Could it have to do with local save/admin rights etc?
Thanks
Jocelyn
Just to comment that i can see the image too.
Hi Jocelyn,
You are right, it is because of your account issue, but I have fixed this problem.
I will do more tests, and will let you know if that is ready.
Mingbo
Hi,i rencently use image viewer on my computerwith win7.Because falescolor 2.0 can’t work in my macbook with win10.I found that image viewer is not satble. I have tried many times,but it just can’t show anything until I use HDR2TIF. And now it can work well even without HDR2TIF. So i just want to notice you that there may still be some mistake in it.
I have the same problem. What is the solution?
@lunzivw @1018340220
Do you have any space or special characters (non-letter and number) in your computer login account?
Yes,my computer login account have “/” and “.”,its my company computer,so is it another way to fix this error?
ImageViewer will save all temporary files to %temp%\Ladybug folder (C:\Users\YOURACCOUNT\AppData\Local\Temp\Ladybug), which is under your user account. But Radiance doesn’t like any special characters. I think this might be the reason. For now, the easiest way for you is using HDR2TIF to convert HDR file first.
