Psychrometric Chart for Outdoor studies
Hello everyone!
So I am trying to investigate strategies for outdoor thermal comfort and trying to push the Psychrometric Chart for this.
I am analyzing the summer time in Kyiv, and previously measured Mean Radiant Temperature for asphalt material (averaged).
So I am trying to predict two situations: 1) (highRad) when the outdoor surface temperature is hot; 2) (lowRad) when it is same as the air temperature; + different wind conditions.
So I am plugging in the mean radiant temperature for the first case, and unplagging it for the second.
The thing that put me into a doubt is that I was thinking that removing the Mean Radiant Temperature would improve the otdoor thermal comfort, but the chart shows me the opposite…
Can anyone help me to understand the results? Perhaps I am doing it wrong?
Bellow are the values for the Total Comfort Percentage:
Also, I noticed that when the mean rad temp is plugged in - the bottom scale shows Dry Bulb Temperature, while the opposite - Operative Temperature. (This is confusing)
Spasibo!
[Kyiv_Psychrometric_Chart_ExtremeSummer2.gh|attachment]
(upload://wWlKtwsiGsOzdNcl9icL3Y3ymDD.gh) (476.5 KB)
Psychrometric chart is not intended, at all, to test outdoor comfort. I suggest to look at the UTCI options.
I’m starting to put together the psych chart for the new LBT plugin and I think I’ll add an option for plotting a UTCI comfort polygon on the chart. But @AbrahamYezioro is right that the legacy psych chart only supports a comfort polygon for the PMV model, which has proven to be a very poor indicator of comfort in outdoor conditions and in buildings with natural ventilation. It’s really only suitable for conditioned buildings.
FYI, if you are using MRT with the psych chart, you should only plug in one MRT value. You will get multiple comfort polygons if you plug in more than one value:
This sound great @chris. Should be explained well to understand the adaptation of one method into another not intended to.
i’ll be happy to test.
Psychrometric chart as a basis for outdoor thermal analysis.pdf (1.1 MB) Thank you for the reply. Just wanted to share with you, if it would be helpful…
Hi @chris happy new year! I am currently trying to show UTCI on a psych chart but can’t find a UTCI comfort polygon. Was this ever added? Thank you!
Happy new year to you too, @jac.lu
It still isn’t added yet, though this method here in the source code gives essentially everything that is needed to calculate it. I was planning to add support for an official UTCI comfort polygon component along with the adaptive comfort chart sometime in the next few months.
