PV panel material import in HB rad library
Dear all,
I am trying to import this material into HB Radiance. I am having a hard time figuring out what is the correct way to do it, or if it is possible.
Could anybody please give me a hint about how to proceed?
The material is composed by two submaterials/properties:
1st definition
void texfunc pucker
6 puck_dx puck_dy puck_dz pucker.cal -s 4.0
0
1 0.0035
2nd definition
pucker ashik2 sunpower_pvcells
4 0 1 1 .
0
8 0.006995137 0.008994048 0.021037648 0.029284513 0.029518141 0.030717789 100 100
Source:
Julio
Just defined a file and copied/pasted your definitions in there. The extension of the file is “.rad”.
PV_Mat_Modifiers.rad (210 Bytes)
Put it in C:\Users\USER_NAME\AppData\Roaming\ladybug_tools\standards\modifiers folder.
If Rhino s open you need to close it and open again in order to take effect.
