Radiance modifier from spectral data
In order to map correct material data, I’m searching for a plugin that converts a measured spectrum (transmittance, front and back reflectance) of a material into a RADIANCE material modifier to connect with “HB face” or “HB aperture”.
I have made a small sketch of this idea:
It has (currently 3 inputs):
  • the path to the csv file containing the wavelenght, the transmittance, front and back reflectance
  • an integer to select between visual, energetic or melanopic investigations
  • a type of either opaque or transparent material
  • perhaps also the thickness
And it has the radiance modifier as output or a list of radiance modifiers to select.
Inside the code should first check, that the input data are of full spectrum range and the wavelength steps are all within a defined length.
I already did a small search but only saw that post LB Radiance Modifiers library that leads to radiance modifier of opaque materials (metal or plastic type).
Is there already something like that existing?
Kind regards
Simon Weber, M.Sc.
Research Associate
Institute for Acoustics and Building Physics
Pfaffenwaldring 7
70569 Stuttgart
Germany
Tel: +49 711 685 66301
E-Mail: simon.weber@iabp.uni-stuttgart.de
Website: http://www.iabp.uni-stuttgart.de
https://orcid.org/0000-0002-6268-8547
You can refer to this website for material selecton and Radiance material definition
Hi @minggangyin, thats the same link as AbrahamYezioro suggested in the link I posted above.
Unfortunately, I can only find material data for “void plastic” materials in this cool database. I would like to get the same for transparent materials like “void trans”. I would have the spectral measurements for this.
kr Simon
Hey Simon, Have you had the chance to figure that out ?
it would be interesting to me aswell to have such library or function to import measured materials.
Timon
Hei Timon,
This is still open. I forwarded it to a similar topic within the RADIANCE forum.
Kr Simon
