Radiation analysis error
I’m using ladybug to do radiation analysis. I’ve previously never had any issues with it until now. Using Rhino 6 and latest plugin updates.
Radiation analysis fails with following error message:
Current document units is in Meters
Conversion to Meters will be applied = 1.000
Radiation study time = 64.283 Seconds…
number of mesh:106819 != number of values:0
Runtime error (MissingMemberException): ‘int’ object has no attribute ‘GetBoundingBox’
Traceback:
line 2772, in calculateBB, “”
line 170, in resultVisualization, “”
line 467, in main, “”
line 493, in script
The geometry I’m using is surfaces, some trimmed some untrimmed.
If I untrim all the analysis surfaces I don’t get the error, but this isn’t ideal as the analysis geometry isn’t representative
Any help would be appreciated.
Regards,
Andrew
