Review request for annual heating and cooling load workflow in Honeybee
I am using Honeybee 1.10 in Grasshopper to analyze the annual heating and cooling loads of a simple office model.
My study evaluates how horizontal external shading devices installed on a south-facing curtain wall affect annual heating and cooling loads. I am comparing several cases with different shading depths.
Model description
  • One office room
  • Room dimensions: 9 m × 12 m × 4.5 m
  • Floor area: 108 m²
  • South-facing curtain wall
  • The south wall is set to Outdoors
  • The north, east, and west walls, roof, and floor are set to Adiabatic
  • Program type: 2019::SmallOffice::OpenOffice
  • Ideal Air HVAC
  • Cooling setpoint: 26°C
  • Heating setpoint: 20°C
  • People: 0.06 person/m²
  • Lighting load: 10.55 W/m²
  • Electric equipment load: 10.33 W/m²
  • Ventilation per floor area: 0.00030 m³/s·m²
  • Ventilation per person: 0.00236 m³/s·person
  • Infiltration: default schedule and values from the SmallOffice program
  • Window U-value: 1.17 W/m²·K
  • Window SHGC: 0.4
  • Visible transmittance: 0.647
  • Horizontal shading depths: 0–500 mm
  • Weather file: [EPW location]
I am using the HB Annual Loads component with a timestep of 12.
Simulation results
For the case with a 100 mm horizontal shading device, I obtained approximately:
  • Annual cooling load: 29 kWh/m²·year
  • Annual heating load: 2 kWh/m²·year
  • Total annual heating and cooling load: approximately 31 kWh/m²·year
The general trend appears reasonable. As the shading depth increases, the cooling load decreases while the heating load increases.
However, I am comparing my results with a previous study that analyzed a similar office model. The previous study reports annual heating and cooling load values of approximately 1.6–1.8, with the unit reported as kWh/m²·year.
This is significantly lower than my result of approximately 31 kWh/m²·year. Because the difference is very large, I would like to confirm whether there is an issue with my Grasshopper workflow, simulation settings, or interpretation of the HB Annual Loads output.
Questions
  1. Is an annual heating and cooling load of approximately 31 kWh/m²·year reasonable for this type of office model?
  2. Is the output from HB Annual Loads already normalized by the total room floor area?
  3. Could there be any duplicated rooms, loads, schedules, ventilation settings, or shades in my Grasshopper workflow?
  4. Is it appropriate to use HB Annual Loads to compare the effects of different external shading depths?
  5. Is there anything in my attached Grasshopper file that could explain why my cooling load is much higher than the value reported in the previous study?
  6. If my workflow appears to be correct, could the discrepancy instead be related to the calculation method, normalization process, or unit reporting in the previous study?
I have attached my Grasshopper file along with screenshots of the workflow and simulation results.
I have been trying to identify the cause of this discrepancy for quite some time but have not been able to find it. I would be truly grateful if someone could take a look at my Grasshopper file and let me know if there are any mistakes in my workflow or simulation settings. Any advice or suggestions would mean a lot to me.
Thank you very much for your time and help.
Hi @goldmoon
There was an interesting discussion about comparing models here:
which might help illustrate some techniques. One method I would try nowadays is simply save out the ‘before’ and ‘after’ IDF or OSM files, and just hand them off to an LLM and ask it to spot the difference(s). I’d bet you it’ll find the difference(s) in a few seconds. Once you know what the difference is in the IDF/OSM file, you can then trace down the issue in the Grasshopper file that is causing it.
best of luck with it,
@edpmay
