I combined several HB surfaces and plugged them into the Run Radiance component (version 0.0.66), which is not recognizing the HB surfaces and giving the following error:
Solution exception:
<Rhino.Geometry.Brep object at 0x0000000000023505 [Rhino.Geometry.Brep]> is not a valid Honeybee object.
First of all, you’d better combine HB_surfaces to make it a zone. Here I think you are using both versions (Legacy and LBT) together which I think is not a logical way to get your analysis.
Definitely, it would be better for everyone to help if you share your file.
Nariman,
Thank you for your prompt response.
I converted all the components to the same version, and I am able to simulate it in its current form. However I tried converting the HB surfaces to a zone, and I get a new error.
You have mixed and matched Legacy and Honeybee[+] components. I recommend uninstalling all Ladybug Tools, install the latest LBT 1.2, and rebuild your file using the latest components. You can use the annual_daylight.gh sample file that comes with the Food4Rhino download of LBT 1.2 as a guide.
