Selecting Individual Simulation Analysis Grid (Mesh)
Hi Everyone,
I am working on daylight and solar exposure analysis with ladybug and honeybee, and i have two questions:
1- Is there a way that i can select each panel from the simulation result (analysis mesh) individually as surface and sort it based on the result value presented by the simulation result? I want to treat each grid (surface) differently.
2- how I can present the value text tag on each grid to be aligned with the geometry surface instead of Z direction projection?
The answer to both questions are yes. It’s much easier to show how if you share a simplified sample file.
Hi Mostapha,
I want to upload the script to share, but it seems that because i’m a new user here, i can’t upload any file here.
From the forum guideline!
https://discourse.ladybug.tools/faq
