Simulation error with Orphaned Door in OpenStudio
I have been getting the following message when I run the simulation. can anyone help please?
1. Solution exception:Failed to run OpenStudio CLI:
undefined method `to_openstudio_shade’ for #Honeybee::Door:0x000002b1eeb37070
This was a bug that I just fixed 4 days ago:
Just like that other discussion, I’m a little doubtful that you actually meant to model an orphaned door as shade. So I might recommend checking your model setup to determine whether this is what you actually wanted.
Thank you Chris for your quick response. I have double checked my model, I am sure I have attached all the doors to parent faces (no orphaned doors). However, I still have this error while running the simulation.
If it’s the exact same error, then you have not disconnected the orphaned doors from the HB Model component. Do this, and it will work.
