hey, I am recently using butterfly for indoor testing. I create a single box with two voids represent inlet and outlet, however, I have some problems with the snappyhexmesh component.
There is no error with it, but it just can’t read the features. I have searched on the internet and couldn’t find the similar issues with mine.
I upload the image here, any help or advice is appreciated.
by the way, the unit is meter.
hey, mingganyin:
thank you for replying me. I attach the GH file here.
Acutally the script i used is the defualt indoor butterfly simulation from its homepage.indoor_airflow.gh (433.8 KB)
I used the defualt indoor cfd gh file that i download from its webside which does not have objects in rhino, and i have checked that the unit setting in Rhino is meter.
do you have other advices?
In the picture you have shared I can see the bounding box have the following coordinates:
(-0.0006 -0.0006 -0.0012) (0.106 0.106 0.0072)
That is a very small region to mesh and it might be why it is failing.
Could you maybe open your blockMeshDict file (it’s in your C:/Users/your_user_name/butterfly/your_case_name/system folder. In the top there should be a line starting with “convertToMeters”. Can you let me know what the multiplier is after that?
thanks. I wonder if the case was generated when rhino was set to mms.
Could you try deleting the case and just remaking it from your definition? Then please post the same file again. If BF is doing what is supposed to do that should work.
i am sorry i may not understand you well. Do you mean delete the ‘blockmesh’ log from the local file and run the snappyhexmesh again? i have tried this which does not work
also i rerun the script from ‘create openfoam case’ by making a new case which shows the same problem
Again so weird. The bounding box coordinates are now in meters which is correct, but the ConvertToMeters factors is at 0.01. Are you sure you are setting everything in mms? It’s weird.
In any case, if you change that line in blockMeshDict to 1 it should work.
