My error is **1. Solution exception:index out of range: 0 **when trying to run the Read Annual Result. First I get an error with the code, which I have attached a picture of and then I see the solution exception error. Thoughts?
When I had this problem it usually was because I had a problem in the context. The component was looking ok, but then some surfaces or meshes were giving problems. Try to unplug it and see if the error remain.
Nevertheless, without seeing your file it is quite difficult to know which may be your problem
Thanks so much for the quick reply, not entirely sure what you mean by unplugging the surfaqce and seeing if the error remains, here’s my file & thanks in advance for any help you can offer.
(you might have to relink the ‘annual_analysis_files’ output from the runDaylightAnalysis componant to the _illFilesAddress input of the readAnnualResults I componant, as I have linked mine directly with a panel and copy pasted path due to another error earlier on)
