Joey_L
October 12, 2020, 10:20am
1
Hi !!
I was simulating annual daylight using the same GH file for different models and only this model has error. I tried a few trial and errors which all has the same error output on the “Analysis Period” panel.:
I redraw the geometry with using extrusions and closed polysurfaces
isolating each hb object to check if it is the geometry issue but there is no error bubble from the hb object panel.
I also tried looking for solutions from below list of forum but could not find any that could solve my issue:
I have been running on an urban context. I have successfully generated a number of results on this scale. However, when I start to run the analysis on a number of the boundaries ( i have to extrude them to run as I ran into another issue where I cannot run them as surfaces or meshes)… The latest issues is that a number of the outlines cause the daylight analysis to throw and error saying: “solution exception: index out of range: 0”
[image] It does happen for every curve ( have been able …
Having a similar problem to the previous posts…
My error is **1. Solution exception:index out of range: 0 **when trying to run the Read Annual Result. First I get an error with the code, which I have attached a picture of and then I see the solution exception error. Thoughts?
[image]
Res_Daylight factor_LovelyBox_ParametricDaylight Analysis.gh (502 KB)
Hi Ladybug Community!
Thanks again for these tools and your contributions so far. I’ve encountered an error recently when trying to read the annual results for a simulation. The simulation seems to have run fine but I can’t seem to isolate what might be cause the error. I’ve looked at similar posts/problems encountered here:
[image]
But no luck on the resolution based on their responses. I’ve also tried rerunning the simulation 2x, after cleaning up my initial meshes. I was wondering …
I am getting “Index Out of Range:0” error when I run shading analysis. Interestingly Honeybee populates the results in its corresponding folder but for some reasons it does not visualize it!
Please see the attached file. The red circle positions where error occurs in grasshopper. Since I do have the results, I attached the “annual Simulation” folder.
https://drive.google.com/file/d/0B7gV9LwHC4QuV0JNdGpESU9ScDg/view?u…
Best
I have internalised the model and attached GH file:
TJC DLG_internalise.gh (1.3 MB)
Hope anyone can help me to identify what went wrong with my model. This is the program version i am using:
Rhino 6
HB v.0.065
LB v.0.0.68
Thanks very much in advance!
