SplitFloor2ThermalZones fails sometimes
Recently I’ve encountered the problem in HB_SplitFloor2ThermalZones component as illustrated in the image below.
There are just simple geometries and in some depth, it happened.
I upload the definition.
Thank you.
SplitFloor2ThermalZones_RH5_HD.gh (522.2 KB)
@hdimor.mr ,
Is this a different issue than the one that you raised here?
If not, we are aware of the issue and we are working on it. It should hopefully be fixed in the next few days, particularly now that I have finally gotten access to a full Rhino 6 license.
Hi @chris, Thank you for the response.
Yes, This problem happens in Rhino 5.
Thanks
I’ve shared the file so it may happen to you or I’m wrong somewhere.
SplitFloor2ThermalZones_H.gh (520.8 KB)
Hi @hdimor.mr,
After I changed the modeling method and deconstruct the geometries SplitFloor2ThermalZones component works perfectly in Rhino 5.
Probably there is something wrong with your model before internalising geometry.
Please find attached:
SplitFloor2ThermalZones_omr.gh (530.4 KB)
best,
Omid.
Thanks a lot @OmidmRashidi :grinning:
